***UPDATED SPECS****
There are some problem areas in my list that I've indicated below; your input on those along with any other suggestions are greatly appreciated. Thanks for helping out!
MOBO (undecided; see GPU):
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard
CPU:
Intel Core 2 Quad Q9450 Yorkfield 2.66GHz
[size=+2]GPU[/size] (undecided):
GeForce GTX 280 SuperClocked Edition
OR
2x ATi Radeon 4850's in Xfire?
I will game on a 22" monitor so I probably won't go above 1920x1200. Which GPU would be the ideal choice? The two 4850's would cost me $200 less, but will they underperform considerably compared to a gtx 280? Which would give me the best overall picture quality?
Also, if crossfire is the way to go, which MOBO would you recommend?
RAM:
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000)
PSU:
CORSAIR CMPSU-750TX 750W ATX12V
HDD:
2x Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache
DVD BURNER:
SAMSUNG Black 20X DVD+R
CASE (somewhat undecided):
LIAN LI PC-A71B Black Aluminum ATX Full Tower
Thoughts on this? Lian-Li's aren't cheap but I've consistently heard good things about them and I really don't want to skimp out on a case.
EXTRA:
SAMSUNG 2253BW Black 22" 2ms Monitor
Thanks again.
CPU:
OR
RAM:
PSU:
HDD:
DVD BURNER:
EXTRA:
Thanks again.
