Hi everyone: my first build!
irridion
I am getting ready to make my first build, I have lsited out my initial config for you comments, please feel free to make any suggestions. I welcome your advice and comments! I am in Torornto, Canada and am trying to buy locally.
Thanks!
Shane
Intel Core 2 Duo E6300 1.86GHz 1066FSB 2MB Cache LGA775 -
Asus P5WDH DL Mobo 975 + ICH7 CrossFire -
OCZ Platinum XTC 2x1024MB DDR2-1000 Kit -
Western Digital Raptor WD740ADFD 10000rpm 16MB Cache HD -
Western Digital Caviar WD5000KS 7200rpm 16MB Cache HD -
Creative Audigy X-Fi XtremeMusic Sound Card -
Sapphire 512MB Radeon X1950XTX PCI-E Video Card -
Antec P180B Case -
Seasonic M12 700W Modular PSU -
Scythe Infinity CPU Cooler -
NEC 18X AD7170 Black DVD Burner -
Mitsumi Black Floppy Drive with Flash Card Reader -
Hauppauge WinTV-PVR 500 TV Tuner -
get a 6400, the higher multiplier will make overclocking easier.
actually get a 6600 you are so overbuilt (compared to the cpu) on the other components why are you going with such puny CPU ?
I like the cpu because it overclocks easily and is cheap to replace if /when I fry it ;)
Looks good. CPU is low end while everything else is high end, hehe... if you want easy to replace, the E4300 has a higher multiplier and is cheaper than the E6300. The only thing it lacks vs the current E6300 is virtualization, which is useless right now.
Agreed. Get the E4300 and drop that expensive, last gen ATI XTX for an Nvidia GTS at least.
