Here's what I bought, any potential problems?
Juardis
Ok folks, this site has been great. After 5 months of research, I have purchased what is in my sig. Some of the parts are here, others are on their way. I plan to OC the 6600 to, at a minimum, 6700 speeds, maybe slightly higher, but I don't want to be too aggressive because I don't want to watercool or ruin my components. In a year or so I plan to upgrade to a 45nm Intel 1333MHz FSB chip (hence the mobo I have) and possibly add a second 8800GTX. I have Win XP Pro and Vista Ultimate, still debating which to install (Vista was given to me).
I plan to game (Oblivion mostly), photoshop, and edit home videos.
Does anyone see any problem putting this together and running it? Any advice on potential problems I could encounter?
looks like a beast of a rig to me. Be patient with the p180. the wiring hassles are well worth it.
Looks good... post some pics! 3Ghz will be easy with that setup on stock cooling. If you get a better HSF, like the Ultra 120, Scythe Ninja/Infinity, or Tuniq Tower, you could reach 3.6Ghz easily.
Yeah, the P180 is a slight PITA, but it's totally worth it.
have fun w/ ur build!
Funny, as much reading and research as I've done on this case, this is the first I've heard that wiring can be a hassle. I already know that the PSU will be a tight fit unless I remove the lower fan and I already know that I'll have to remove the middle enclosure that houses 2 3.5" drives to fit my 8800GTX, but as far as wiring hassles, I hadn't heard that. Thanks for the heads up.
Hehehe.. thats funny, because that usually concerns most would-be P180 owners... "are my PSU cables long enough?"
Damn, you didn't research enough then. LOL!.
Yeah the P180's wiring is a bit of a hassle but if you take your time and plan things out before hand, you should be ok.
Here's a link that you should definitely check out:
http://www.silentpcreview.com/article255-page12.html
Just scroll down to the " TIPS & HINTS FOR ASSEMBLY" section.
Also another link for some reading:
http://hardforum.com/showthread.php?t=1178058
My coworker bought this case and said it was great and not difficult to install everything. The Zeus I bought is purported by jonnyguru to have cables plenty long enough for full tower cases. Anyway, good tips in the silentpcreview article. Thanks for the link. I think some of those tips are no longer valid though with the "b" version of the case.
If you're going sans lower-middle fan, I heartily recommend the lower-front fan mod. There is a thread on it here, but the pics are down. I'm sure there are pics somewhere else though.
Either way, its really easy. basically just involves drilling out the bracket in the lower-front chamber to allow for the mounting of another fan. You want have a bracket to mount on the grille like the middle-front fan, so you'll need some washers as well.
