Hercules 9800XT Died
I turn on my pc, no signal thru my monitor from my vid card, I can hear windows loading in the background from my speakers, still no signal, i turn on/off my monitor, tried thru analog and DVI, still no signal, Checked the card, the fan is spinning, took it apart-put it back together, still no signal, doesnt work. Put in my crappy G4Mx420(PCI) vid card, works fine, windows loads, everything works fine. What the hell, I didnt overclock it, i used overdrive 418mhz was its last clock, everything is cool-warm to the touch, it didnt overheat, temps were the day b4 58C-63C. The mobo beeps like 2 beeps and a long beep when the pc boots up with 9800xt, no beeps with g4mx420, i dont know what the beeps mean. Any Ideas? :confused:
Try throwing the 9800XT in your system and clearing your cmos?
It sounds like... 2 short beeps and then 1 long beep? sos? lol...
No really, no problems with your keyboard or anything else? >.< I don't know. Clearing the cmos might help.
Did the fan on it die?
If you got it retail, you should be all set. You may be screwed if you got it OEM.
the fan still works, i tried clearing the CMOS, and restarting the system about 5 times, i get same results, no signal from my video card, I bought it retail from newegg
