Helping with my friend's build
mechapilot
Hi guys
I was looking for a little more advice in case I missed anything. I'm helping my friend build a new Sandy Bridge 2500k build and wanted any ideas/opinions. We are ordering in just a few days and wanted to triple check the build with some of you guys.
It's a gamer box but also a "work at home box" so it will have the ms suite and a few work apps but nothing major. I think he wants to build a crossfire box.
OS: Win 7
CPU: Intel i5 2500k
Board: ASUS Maximus IV Gene-Z LGA 1155 Intel Z68
Bought in this combo:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.763036
Cooler: CM Hyper 212+
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
I think my friend has a green 1 TB drive from his last build he wants to use and 8 gbs DDR3 corsairs he already has. He has antec 850 watt psu.
The idea is to eventually go to crossfire, he already has a HD 6950 GPU and a very large older tower. He got it from a guy with a watercooler setup and we are thinking of taking out the water cooler and going back to air. Do the standard OC and push to 4Ghz but nothing wild.
I like ROG personally, but some ppl say it's spendy. For 150 in that combo deal i think its a good price.
What do you think of the build? Can you see anything goofy or weird? Any better parts or ideas? Your input would be greatly appreciated. :p
What Corsair RAM does he have? More importantly: Are the RAM rated at 1.5V or lower?
What's the exact case that your friend has? If you don't know the model or can't find it, post a pic of it.
So far, if you were going for a mATX setup, that build would be good. However if your friend does actually have a decent older tower, I don't see a reason to get that Asus mATX mobo. Even at $162 with the discount, that Asus mobo seems overpriced for what you're getting. Unless that Asus mobo has some features that your friend really needs, I recommend this MSI mobo instead especially since it has extra spacing between the PCI-E slots which allows for video cards in Crossfire or SLI to run a bit cooler:
$145 - MSI P67A-GD55 Intel P67 ATX Motherboard
What resolution is your friend using for gaming? What's the model number (and age) of the Antec PSU?
Hell, what's the brand and model of the 6950? What's the (specific) model number of the RAM?
If it seems like Danny Bui and I are trying to pull teeth... well, we are. :p But we want to make sure that parts that you already have play well with the parts that we (and others) are recommending.
Cool thanks a lot of the input Danny I'm checking with my friend to get you some answers. Your right $20 bucks is $20 bucks. But the Republic gear is pretty awesome for bragging rights. I compared the boards and they do look very close in features...
Hello Tirades - my friend wants to play at 1920 x 1080, the Antec was purchased last year, not sure of the model but its a 800 watt psu. My friend decided not to go crossfire now, but maybe later.
The ram we aren't certain. We know its corsair DDR3 ... we think it's CORSAIR XMS3 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 133. We are confirming that tonight. if it is XMS3 its rated at 1.5V (all xms3 appears to be) He's gonna read the stick off the ram when he gets home.
Tirades, Danny thanks for your input. You know how it is before you plunk down 4 bills... you just want to make certain its the right choice and so far i think we are ok.
