I have an e8500 retail box cpu sitting here without a mb, what is a good motherboard to overclock this bugger i was @ fry's looking @ the p5q se for 100 bucks is that good??
sorry im old school tbirds, voltage tec and water LOL back when abit boards were good now ive got a dummy in9-32x-max sitting on the floor that my son works on with his plastic tools.. it should be good and ready for rma in a week or so LOL
ohh and btw im not too interested in firewire all the bells and whistle crap all i need is a good solid board with atleast 2 usb ports and a lan card
so by my understanding you're paying the extra $100 dollars for that with the p5q pro, still getting that good, solid p45 chipset correct me if im wrong
The P5Q Pro is actually a better overclocker than the P5Q SE. In addition, the P5Q Pro has a significantly better placement of the 24Pin connector than the P5Q SE that does not obstruct airflow, choice of heatsink or cablemanagement. Also, the Pro's north bridge cooling and mosfet/phase power cooling is significantly better than the that of the P5Q SE due to the usage of heatpipe cooling system. Finally, the Asus P5Q Pro is only $30 more than the P5Q SE: Asus P5Q Pro Intel P45 Motherboard - $130
In fact, IIRC, the UD3R/P overclocks a bit better than the Asus P5Q Pro.
As for your RAM, assuming that you go with a 1:1 ratio, you should be able to get around 3.8Ghz. Some math:
Stated FSB/4 = Actual FSB
Actual FSB x 4 = Stated FSB
Multiplier x Actual FSB = CPU Speed
1:1 Ratio: 2 x Actual FSB = RAM Speed
1:1 Ratio: FSB = 1/2 RAM speed
Note that C2D systems don't see a performance increase with any ratio higher than 1:1
E8500:
Multi x Actual FSB, Stated FSB, RAM Speed = Clock Speed
9.5 x 333Mhz, 1333Mhz, DDR2 667 RAM = 3.16Ghz <== Stock Speeds
9.5 x 400Mhz, 1600Mhz, DDR2 800 RAM = 3.80Ghz <== Easy OC
9.5 x 450Mhz, 1800Mhz, DDR2 900 RAM = 4.27Ghz <== Excellent OC
9.5 x 500Mhz, 2000Mhz, DDR2 1000 RAM = 4.75Ghz <== If the computer gods are smiling on you.
the gigabyte board looks promising i almost bought it today but they didn't have it in stock, only the ddr3 based board was in stock and i couldn't justify buying ddr3 yet :/
one more question, kind of like back in the sdram days if you bought low cas ram you could run it at a higher cas but faster bus speed, possibly beable to achieve that with 4-4-4 ram run it @ 5-5-5 @ 900mhz instead of 4-4-4 800mhz i think you'd achieve better results from 900mhz 555 than 800 444
was that way atleast back with running pc133 @ 2-2-2 compared to running it at lets say 150 2.5-2.5-2.5
either way i dont care i have an e6750 right now @ 3.2ghz a e8500 is basically that fast stock with just being an all around better design of cpu
Running higher timings generally allows you to run at higher frequencies as well. This is helpful if you need to overclock your RAM to achieve a higher bus speed. However, overclocking the memory by itself doesn't have a significant effect on the performance of Core 2 systems, so you'd be better off focusing on getting the most out of your CPU before you really start to consider taking your RAM to its limits.
yeah i understand that im looking at the fact lets say i achieve 450fsb w/ my e8500 i could run the ram @ 900mhz 5-5-5 possibly and achieve better results running it 1:1 to my fsb compared to leaving it at 800mhz 4-4-4
