HELP
Rydawg5143
I wasn't to happy with the preformance of my 4870 so i took it out, unistalled drivers via drivercleaner. I then put back my 4850 and started to instal drivers but everytiem I do CCC get part way through and then fails due to "INF file was not found" therefore the driver cannot be installed. Please help :)
I had a problem with driver cleaner also last night. I uninstalled my drivers and used driver cleaner to delete everything. I then rebooted my system and when windows was about to start up, i would get a bsod. I ended up re-installing windows again and now everything is fine.
What didn't you like? The 4850 is close to the 4870? If that's the case....I may as well just get a 4850 and call it a day. :p
I mainly play TF2, which is moreso taxing on the CPU than the GPU, I upgraded as follows
19" w/ 8800GT to 19" w/4850 and noticed a slight increase in frps and the quality of the game
19" w/4850 to 22" w/ 4850 and there was no difference in frps or quality
22" w/4850 to 22" w/ 4870 and again was no noticable difference
I then traded the 22" with a 24" and begun to have lock ups and below avg frps while in game.
So i decided it wasn't worth it to upgrade to a 24" monitor or a 4870 when my ole 19" and 4850 works great. I'll be returning the 22" and 24" monitors along with the 4870.
