Help with some components
hi, i want to build a new pc reusing some components. im not from U.S and i can only buy from amazon. My budget is 400$ maximun 500$. what i really want is an intel i7 4790k, a motherboard for it and some RAM. My last PC just die on me, and amd phenom 975. I would like to get the best i can, on the motherboard i would like to get all new tecnologies available usb 3.0, sata 6gb, pci-e. Maybe later i would get some new GPU with a power supply. I really like to taste the fast booting and overall speed boost from an SSD but is not a priority.
First gaming, web browsing
400-450$, i would buy from amazon
Not from U.S, arriving agust 23, leaving september 7
CPU, motherboard and RAM 8gb or 16gb, SSD.
* Power supply Thermaltake tt-450nl1nh-1 450W
* 2x 2tb seagate HDD
* GPU: HD radeon 5570hd
* Monitor
* LG DVD-DL burner
6) Will you be overclocking?
No
HP w2558hc
As soon as possible, i would like to buy before i arrive, i would free super saver shipping
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0,sata 6Gb,
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
i already own windows 8.1 licensed
Yeaaaah, here's the deal: You should buy a new PSU from the get-go since your current PSU is not good enough for a modern system.
In addition, you're only gaming so there's no real reason for you to get the Core i7 4790K nor are you overclocking so a K series CPU is a bad idea.
So here's what I recommend instead:
$200 - Intel Core i5-4590 CPU
$88 - Gigabyte GA-H97M-D3H Intel H97M mATX Motherboard
$77 - Crucial Ballistix BLS8G3D1609DS1S00 8GB DDR3 1600 RAM
$70 - XFX TS Series XFX TS 550W PSU
Total: $435 shipped
Thanks, i7 would be too mucho? I was trying to get the best I can. But I may compromise some other stuff, but you are right.
Yes, too much and not even needed. Even if you had a $1000 budget, I still wouldn't recommend the Core i7 since you're not doing anything that would justify spending that extra $100 for that Core i7.
Again, you're not doing anything where it would make sense for you to get the Core i7. Gaming does not require a Core i7.
