Help with Overclocking Please (E6600) Weird Memory Problems
Buckster
I have an E6600, P5-B Deluxe, and Corsair 6400 C5 RAM.
@ 352 fsb - CAS4 - RAM 1:1 I can run Orthos Blend no problems for hours
@ 352 fsb - CAS5 - RAM 4:5 Its only stable for 3 mins, same Vcore
OK - should be the RAM - BUT it passes MemTest86 in DOS with no errors at all ? Is MemTest not a very good test ?
Mark.
Your memory is running faster at 4:5 isn't it? At 1:1 your memory is only running 700mhz or so, but at 4:5, it's running 880mhz.
