Help with overclocking Gigabyte
Blackstone
I am trying to help a friend overclock his core2duo e6600 on his gigabyte GA-N650SLI-DS4 motherboard. He ran into this problem:
"I couldnt change the FSB-Memory Clock Mode to Linked or unlinked because even after changing the CPU Host Frequency to 266 It would say Voltage not optimized. I tried to boot like that with everything that i could and it brang me to a screen that said that i had to change the voltages."
He then went on to tell me that the only way he could get it to say voltage optimized was to set voltage control to auto.
We want to manually set FSB-Memory clock mode and set ratio to 1:1. Further I want manual control over the memory timings and voltages. What does this voltage not optimized warning mean?
Most Gigabyte boards require you to hit CTRL-F1 for "advanced features" in the bios. Memory timings should be available after you press that combo.
Not sure about the other part, but is there a newer bios available? Maybe it's just a glitch in an older bios.
