OK, I am going to try to follow the guidelines here in order to find the best bang for my buck.
I prefer Intel & Nvidia over AMD/ATI just because I am more familiar with it... the few times I'd used AMD/ATI I had bad experiences.
I don't want to go cheap (as in lower quality) but I also don't need top shelf or I-gotta-have-it-because-it-just-came-out stuff.
Office PC, Point of Sale/Accounting software, Parts look-up microfiche software (files on the server and not on the pc/workstation), Web browsing, e-mail + light MS Office (Word + Excel), Some/light Video and Image editing
$500 to $600 before taxes and shipping
3) Where do you live?
Miami, Florida
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need. Case, Mobo, CPU, PSU, GPU, RAM, KB + Mouse, Monitor... I should also add that KB+Mouse and Monitor could be discarded if need be.
WDC WD160 Velociraptor, CD Rom, DVD Rom, Floppy Disk + Card Reader,
6) Will you be overclocking?
No
I have a Hyundai ImageQuest L70s that I plan to discard and I plan to buy a std 22" LCD
As soon as I can find the best price and combo
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
10/100/1000 Ethernet card if not included with mobo, SATA,
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Windows XP Pro 32 bit
Here are some of the things I have seen so far: I literally went with price here, did not take into consideration quality or whether components had good reviews.
http://cgi.ebay.com/ws/eBayISAPI.dl...ef46abb&itemid=320489513680&ff4=263602_304652 $264.95 - Intel E7500 Core 2 Duo 2.93 CPU-Motherboard-RAM Combo
http://www.axiontech.com/prdt.php?item=89723 $235.99 - Clarkdale Combo Deal 1: MSI H55M-E33 Motherboard with Intel Core i3 530 Processor and 2GB DDR3 Memory
http://compare.ebay.com/like/320601...ef46abb&itemid=320601154836&ff4=263602_304662 $223.95 - Intel E6600 3.06GHz Dual Core CPU-Motherboard-RAM Combo
http://www.buy.com/prod/asus-vk222h...50-16-10-2ms-0-282mm/q/loc/101/208286866.html $223.95 - ASUS VK222H Widescreen LCD Monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16811121096
$39.99 - HEC Blitz Black Steel Edition ATX Mid Tower Computer Chassis Gaming Case w/ Front Blue LED 120mm Fan & Top 120mm Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147023
$44.99 - Rosewill Blackbone Black Steel / Plastic ATX Mid Tower Computer Case
$58.99 after MiR - NZXT M59 Case + OCZ 600w PSU
Miami, Florida
No
