Help with no video signal
NotJay
My pc suddenly stopped working and spec is in my sig
it boots up but no matter what I do , I keep getting no video signal
I tried
1. Switching out ram
2. Booting with no ram
3. Reset bios
4. Booting with cpu disconnected
5. Booting with motherboard graphic instead of dedicated graphic
6. Switching out to another dp cable and hdmi cable
Monitor does work fine with my ps4 and other stuff so you can rule that out
At this point, Im suspecting my motherboard
Anyone have some other method to narrow down my issue?
try boot with the direct key (on the motherboard) "should" boot you right in to the bios?
plug in a pc speaker (the beep beep kind) get the beepy error code.
I don't think this one has the digital code thingy?
No luck with direct boot still have no signal and no sound from speaker
It's either your power supply or motherboard or cpu. Only way to narrow it further is to start replacing stuff.
Ok, what happens when you test the system OUTSIDE of the case with just the CPU and RAM installed with the onboard video enabled and connected? Physically remove the video card.
