Help with New PC Build
Mainly Gaming and Video Editing
$1000.00 total
3) Where do you live?
Louisiana
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU,RAM,MB,VIdeo Card,Case,Power Supply,Hard Drive(s)
N/A
6) Will you be overclocking?
Yes
22"
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I would like a raid controller and SLI or Crossfire would be nice if I could fit mulitple video cards into the budget.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Windows 7 32bit and XP Pro 32 and 64...not sure what I'll use...any advice?
Thanks in advance. Any help/recommendations are appreciated.
$340 - Intel Core i5-750 + GIGABYTE GA-P55A-UD3P ATX motherboard combo
$105 - G.Skill Ripjaw Series F3-12800CL9D-4GBRL 2 x 2GB DDR3 1600 RAM
$160 - XFX HD-577X-ZNFC Radeon HD 5770 1GB PCI-E Video Card
$70 - Western Digital WD6400AAKS 640GB 7200RPM SATA 3.0Gb/s Hard Drive
$26 - LG GH22NS50 DVD Burner
$75 - Antec Earthwatts 650W PSU
$50 - Cooler Master Elite 335 RC-335-KKN1-GP ATX Case
Total: $826 plus tax and shipping.
Go with Windows 7.
Dannys build is actually perfect. Meets the budget even if Windows 7 O/S is added. :)
Go with Windows 7.
Go with Windows 7.
I would splurge and go with a better case, win 7 is only what, like $100, so he has another 30-40 he could spend on a case. The 335 is a decent case but it with the budget I would get something with more features.
All great recommendations, thanks Danny. That config looks very promising. I like the processor and MB combo. I may look around for other cases and I'm researching the Video Card (looks good so far). I also may get a couple HDDs to put that raid controller to use.
