help with new card purchase
Just wondering if a new 1070 or 1080 would work ok with this system, would i bee bottlenecked?? do i need to upgrade cpu and mobo mem and suchforth.
2600k @4.6ghz watercooled
asus maximus IV extreme z
evga titan 6gb +150 +70 watercooled
sony gdm-w900 1920x1200 75hz
steammocking
512gb sammy850 pro ssd
3x wd reds 3tb
soundblaster z
Q acoustics 5.1
onkyo tx-sr876
steamhappy
16gb Corsair
koolance resevoir
850w NZXT:UT2004shield:
Obsidian Series® 800D Full-Tower Case
The CPU may hold you back a little in some games, but otherwise, I suspect it will be reasonably well matched. With a GTX970, I was just starting to see some instances where the GPU would run at about 90% load while using a 2500K at stock speed (3GHz, I think). With a 1070 or 1080, it totally won't surprise me to find that the GPU is running at like 60% load while rendering 150FPS, and the CPU is the limiting factor.
You don't need that much GPU horsepower for 1200P, generally speaking, though. I expect you could wait a few weeks and spend half as much on an RX480, or get a sweet deal on a used 980Ti or something, and do just as well.
thanks a lot. The thing is i always find that after ramping up all the settings and adding mods i do run into performance issues. Thats why i want to get a 1080 or 1070 minimum. Theres never enough hp. especially with the new games coming along. Does a good overclock on the cpu help to alleviate the gpu load issue?
Yes, overclocking will help. If you're running at 4.6 GHz, then you're already running ~30 percent faster than stock anyway, so the limit before the GPU starts running out of stuff to do will be higher.
I can't say how much higher without more information. The GTX 10 series will totally work for you, though. If that's what you want, go for it.
