Help with new build... $600-$800
n00ti
gaming
$600-$850max including tax&shipping
Los Angeles, CA
I need ATX mobo, CPU, memory, video card.. that's it.
700w OEM ATX PSU, Seidon 120m liquid CPU cooler, SoundBlaster x-fi sound card, 3 seagate 500GB sata hard drives, DVD burner, alienware fulltower case.
6) Will you be overclocking?
no
1920x1080
asap
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
need pci slot for sound card, need onboard ethernet, USB. nothing fancy.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I have a new & legit windows 7 home 64bit license
Which Alienware case?
Which 700W PSU?
What games are you planning on playing?
2006 Alienware Area 51 tower
Which 700W PSU?
OEM. came with alienware case. label says "HIPRO"
World of warcraft. Skyrim. 2012-2013 releases if possible. Steam.
So here's what I recommend:
$180 - Intel Core i5-4440 CPU
$88 - Gigabyte GA-H97M-D3H Intel H97M mATX Motherboard
$74 - Crucial Ballistix BLS8G3D1609DS1S00 8GB DDR3 1600 RAM
$113 - Crucial MX100 256GB SSD
$210 - SAPPHIRE DUAL-X 14-202-099 Radeon R9 280 3GB PCI-E Video Card
$60 - XFX TS Series XFX TS 550W PSU
$50 - NZXT Source 210 Elite Black ATX Case
Total: $775 shipped plus tax.
Let me explain the build:
Your current case and PSU are not good enough for a current generation gaming system. I'm more than willing to bet that the above $50 case will outcool that Alienware case. As for the PSU, it wasn't that great to begin with so after 8 years with it, it's time to replace it. Hence the new PSU and case, both of which are superior in almost every way.
Yes that's a mATX mobo but your budget (once tax was factored in) really couldn't fit in a decent ATX mobo. Plus you didn't really say anything where an ATX mobo would be absolutely recommended.
Even if you had all three of your 500GB hard drives in a RAID 0 array, they would still be slower in overall responsiveness than a single SSD. A SSD makes the biggest difference in a current generation gaming PC since the storage/OS drive will almost always be slower than the rest of the PC. So might as well get a SSD to close that performance gap.
Excellent. Yes, this is exactly what I am looking for. Everything makes sense. Will purchase now. Thank you.
