I just purchased x2 3800+ last week and installed it last night. At stock speeds I get 43 degrees C, while using two instances of prime 95 (torture test). Is this too high?
Also I would like to get some advice/help for overclocking it should I move this to the overclocking section.
I have :
AMD 3800+ x2
Asus A8N-SLI Deluxe Bios 1015 (bought it about a year ago)
1 GB ram OCZ Plat Rev 2
2 raptors in sata 1 and 2 in nvraid
1 500 Gig in nv sata slot 3
6800 ultra xfx stock speed
latest drivers for everything
Seasonic s12 600 W power supply
antec LanBoy
xp120 heatsink w/
vantec 120 mm thermo controlled fan.
I also tried to overclock my 3500+ saturday witht his set up but couldnt get past 214 fsb.
I cant seem to shutdown or restart my pc either since I updated my bios for x2. It seems to shutdown and then hang after the windows shutdown window disappears.
I have :
AMD 3800+ x2
antec LanBoy
xp120 heatsink w/
