help with my first build
1) What will you be doing with this PC?
Gaming , movie and internet ( I only play The Battle for middle earth- The rise of the witch-king) I like to play with max out setting.
2) What's your budget?
500 tax and shipping not included .
3) Where do you live?
Ca, Costa Mesa
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything
keyboard and mouse
6) Will you be overclocking?
NO
hp 24 ( already have)
within 2 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
dont know
10) Do you already have a legit and reusable/transferable OS key/license?
yes. win 7
COOLER MASTER Elite RC-334-KKN1-GP Black SECC ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119190 $45
CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Certified Compatible with Core i7 Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008 $50
GIGABYTE GA-MA770-UD3 & Phenom 2 x4 920 combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.183653 $202
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122 $43
Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074 $55
SAMSUNG 22X DVD Burner Black SATA Model SH-S223F - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151171 $25
SAPPHIRE 100265HDMI Radeon HD 4830 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102822 $85
Total before S&H $505
For an extra $5, you can get another 180GB of storage:
$60 - Samsung Spinpoint F DT HD502IJ 500GB 7200 RPM SATA 3.0Gb/s Hard Drive
That game isn't demanding at all, but you do have a huge monitor. Will you be trying any other games?
thanks you, do you have any suggestion for intel? or AMD is the best solution for me?
at this time yes... I would act fast and get the 920 combo before its sold out.
I agree... if you miss out on the combo, you'll be stuck with an X3 or X2. An Intel quad alternative would likely cost around $50 more. Though, you don't need a quad for your game. A dual core is all thats needed, like the AMD X2 7750 Kuma.
