My brother works at Intel and so was able to get me a QX9650 for free. Based on this, I decided to build a new computer! Here's the current components I have selected:
CASE: Thermaltake Armor+ VH6000BWS - $200
PSU: Thermaltake W0116RU 750Watt - $170
CPU: Intel QX9650 Core 2 Extreme - FREE
HEATSINK: Zalman 110mm 2 ball cooler - $54
MEMORY: OCZ Reaper HPC 4GB (2 x 2GB) - $100 -- I'm not 100% on this
VIDEO CARD: EVGA GTX280 1GB - $650 (for now)
HARD DRIVE: WD VelociRaptor 300GB 10k RPM - $300
As you can see I'm looking for a fairly future-proof gaming rig. I already have a 24" Dell monitor which has 1920x1200. I'm looking to spend about $1500-2000.
My questions are this:
1. Do you see any problems / suggestions?
2. Most importantly, can anyone recommend me a good motherboard for this kind of setup? I am going to have one GTX280, but in the future I might add a second (I will never triple-SLi so that's not an issue).
3. Based on motherboard recommendations, any suggestion for different memory card?
Thanks!
Thanks!
