So I haven't built a PC in about 4 years and I'm not very up to date on current technology. I want to use this primarily for sound recording, but also for gaming. I have an external m-audio sound device that I will be running with protools. I also already have a monitor that I'd like to keep. My budget is around $2000. I've done some reading and this is what I've come up with so far:
CPU
Intel Core 2 Quad Q9550 Yorkfield 2.83GHz LGA 775
Heatsink
ZALMAN CNPS9700 LED 110mm 2 Ball CPU Cooler - Retail
CASE
NZXT Temptest
PSU
CORSAIR CMPSU-620HX 620W (modular)
GPU
SAPPHIRE 100251SR Radeon HD 4870X2
HDs
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA
(i wanna put 2 of these in a raid 0 config, and then either get a 3rd for backup of important data, or else an external firewire/usb drive)
That's all I have selected so far. I know a lot of people will recommend a cheaper CPU but I wanna stick with the Q9550 as I expect it to hold up for a good 2-3 years. I'm also fairly sure I wanna get DDR3, even if its not insanely faster, for the same reason as getting the Q9550.. I think it should last a while.
Some other notes/questions: I don't plan on gaming in resolutions higher than 1024x768 or 1280x1024 at the max. Is that videocard overkill? If I do want to upgrade my monitor down the line I might get a second 4870X2 and put it in crossfire. But for now it should be more than enough for my gaming needs, right? Two other things that might influence decisions... I don't really ever plan on overclocking anything (maybe the CPU a small amount.. up to 3.0 ghz?) and I don't want to bother with water cooling (thus the tempest case). And I will probably also get a fan controller so I can turn the fans down at night. Will 620W be enough for all this? Or should I just get the HX1000 now so I don't have to get one later on down the road.
So the biggest question is what mobo to get. I've always had good luck with ASUS and was looking at the P5E3, but I would have to get a seperate raid controller.. which is probably preferable anyway I think. Also for memory, I heard corsair and crucial were good brands (planning on getting DDR3 1333 mhz).
So that's about it, I think I've covered everything. Thanks in advance for any input/suggestions. So many decisions, ahhhh!
CPU
Heatsink
CASE
NZXT Temptest
PSU
GPU
HDs
