Alexsktbrdng
- Dec 31, 2002
Hi guys,
Recently I've been having some problems with my computer, in that it will not start up. When I hit the power switch on the computer, I hear one beep, and all the fans start up (psu, mobo, case fans, gpu, etc) and the computer sounds as if its starting fine, but nothing comes up on the screen. The computer then seems to "sit" in that position until I turn it off. Also, I am unable to turn the computer off any other way then either pulling the blug or flipping the switch on the psu. I am unable to use the mouse or keyboard and the computer does not even seem to get to its bios. I have tried numerous solutions to this problem:
Replaced Psu
Replace Graphics card
Reseated everything (ram, hd, cd drive, gpu,)
Reset CMOS
and still no luck. Could I be missing something stupid (like forgetting to plug something in), or does the problem sound like something I have not mentioned. Thanks in advance for any advice/help you may provide.
Thanks again,
Alexsktbrdng
PS my specs are as follows:
Nforce4 Ultra BFG Motherboard
Amd proc
Ati 800 pro/ 1300 pro vid card (1300 is replacement)
Antec psu
Replaced Psu
Reset CMOS
Thanks again,
Alexsktbrdng
Amd proc
Antec psu
