Gaming, everyday usage and some overclocking. (mainly, finding a max stable OC for 24/7)
1700-1900, tax/shipping not included.
San Jose, CA. Our microcenter closed down last year. Sad.
CPU, CPU Cooler, GPU, PSU, Case, Ram, SSD, Motherboard, Montior, Possibly sound card.
Keyboard and Mouse
6) Will you be overclocking?
Yes but nothing hardcore. Just to find a simple max OC (like say running 4.5 on a 4670k)24/7)
I would like a 27inch to use as a TV as well. So 1080 or 1440. But I can settle for 24inch in 1080 to help the budget.
Within 2 weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
SLI, USB 3.0 and just good overall quality. Good overclocking capabilities.
Already have legit Windows 7 64 bit Pro.
I have build plenty of computers in the past but been out of the game for awhile. I last helped my brother put together Sandy Bridge when they very first came out. Where I am confused (and I have done quite a bit of research and still am) is just the best brands/models now a days.
What I been thinking was something like 4670k, GTX 770 (SLI if possible but I can upgrade later to fit the budget), 8gb ram (I don't mind putting a little extra for 2133 speed) 850w PSU, Corsair Hydro 100i or 110, 250gb SSD (I have a USB 3 external for extra storage, I don't keep many games installed at once).
I am pretty clueless with the case and motherboard. For case, I like the Corsair Carbide 540 but think the footprint will be awkward. Any case with great airflow that is easy to mount a Corsair 100i or 110 inside, I don't really like very cramped cases.
Motherboards, I like the ASUS Hero but heard there are much cheaper boards around that OC just as well. I don't need tons of features, just really good OCing capabilities and reliability.
For a monitor, something mainly good for gaming and a secondary TV. I'm really torn over a IPS or 120hz, 24 or 27 inch and 1080 or 1440 (for a 27") resolution.
Thanks for any help in advance. Very excited to build me a new rig after I get rid of my laptop.
Keyboard and Mouse
Within 2 weeks.
