My goal is to build a cheap 24/7 server that doesn't use a lot of power. I don't need super multimedia capabilities. I really prefer mini-itx size but if I have to I will go up to mATX or whatever is the next size up. Max budget: $400 but would prefer to spend around $300. I don't have ANY parts I can re-use
Primary uses: Windows server 2008 with Sql Server 2008, ASP.NET/IIS, NAS/file server.
* Need to support 4GB ram
* need 1 gigabit NIC
* need dual core CPU but doesn't have to be super fast
* prefer 100w or less at load (60-80w ideally)
* 1 SATA hard drive (maybe add a 2nd one later)
I was thinking about the intel Atom 330 motherboard on newegg. But it seems like the chipset uses more power than it should, and it only has 1 ram slot. Can I put a single stick of 4GB ram in there? Or will that not work.
Are there any other atom 330 motherboards on the market? Or any coming soon?
If not, I was thinking something like the following:
CPU: AMD X2 4850e 45W $55.25 http://www.newegg.com/Product/Product.aspx?Item=N82E16819103255
RAM: G.Skill 2x2GB $39.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
MOBO: Zotac GF8200 $129.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16813500021 has $10 rebate
CASE: Foxconn mini-itx case with 150W PSU $52.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16811153099
HD: WD 80GB SATA $34.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16822135106
Total Cost: $335 shipped
I'll add a 2nd high capacity (or replace 80gb) later on. I don't need a ton of space for now and trying to keep cost down. Actually I might not buy the dvd-rom drive and just temporarily use the one from my desktop while installing the OS. I wish there was a cheaper mini-itx motherboard for AMD. I actually prefer intel but I'm guessing any C2D will draw too much power? WIth the specs above, what kind of idle/load power draw do you think I'd use?
Am I missing anything in my build? Big things, or little things like will the PSU in the case have the proper connector for the mobo? What about thermal paste & cpu fan/heatsink?
Sorry for all the questions. I'm open to any ideas / suggestions. I'd love to find a better atom 330 mobo, or at least know that one can use a single 4GB ram stick.
Lastly, what about the everex gPC mini? http://www.newegg.com/Product/Product.aspx?Item=N82E16883118007 $339 but looks like it only supports 2GB ram
Again, can I put a single 4GB stick in there?
