Hello there. I've been having some trouble with my computer. When I press the power button the only thing that happens is the fans (and the SATA devices) turn on. To be more specific, the case fans and the fan on the GPU turn on, while the CPU heat sink fan does not turn on. Actually, occasionally the CPU heat sink fan turns on, but very weakly. In addition to the fans, the motherboard's lights turn on, and the DVD drive (and I think the hard drive) turn on as well. Apart from that, nothing happens, nothing on the monitor, no post, no beeps, nothing. I don't know if this board has a built-in system speaker or not.
See normally before the problem, when booting up the fans would spin for a few seconds, and the GPU fan would spin really fast and sound like a jet engine, and then a couple seconds later the system would POST. Right now it's only reached the "jet engine" stage, so to speak.
A small tidbit that may or may not be relevant is when I turn the thing back off, by hitting the PSU switch, it goes off and then maybe 5 seconds later the blue light in the PSU flickers for a second despite the switch being off.
I know for a fact that the motherboard is not at fault. How? I replaced it, thinking that it was the cause, and now today, having just recieved the new one, the same problem is happening. Hence me making this thread.
Here's the current specs:
Q6600 Quad Core
2x2GB Mushkin Memory
600W OCZ Power Supply
Gigabyte EP45-UD3P motherboard
EVGA 8800GT GPU
I really have no clue now which part I need to replace. I've taken apart and rebuilt the thing countless times so don't ask that. Unfortunately I don't have another computer which is compatible with these parts to individually test them, so I can't do that either.
My intuition says it's either the power supply or the processor... but I really can't be sure. Any ideas?
Q6600 Quad Core
EVGA 8800GT GPU
