Thadius856
- Dec 26, 2008
Primarily gaming - mostly MMOs (multi-clienting), some RPGs, some RTS (Civ V), some retro and casual, some catching up on a few years of great games I've missed (Arkham Asylum, Portal 2, etc).
3x1 portrait Eyefinity is a must initially, with enough overhead left to go 5x1 portrait in the future. If some games can't be pushed past 3x1 smoothly, that'd be fine; I'd just use the outside monitors for web/reference/guides/walkthroughs/videos while playing.Otherwise, the usual web browsing and video playback (DLNA push).
Hopefully $1200 or so initially, with planned upgrades later. Can go higher if I needed, but don't want to waste on overkill if I don't have to.
US. Nor Cal, in a cow town between Sacramento and Yuba City. 8% local sale tax rate.
CPU, RAM, GPU, Mobo, heatsink/fan.
Full-ATX case (Antec 1200 or CM HAF 932)
Power supply (Silverstone SST-ST70F 700W) - will upgrade eventually
SSD (Crucial M4 64gb CT064M4SSD2)
Several assorted 1TB 7200rpm HDD's
DVD-RW and BD-R (Lite-On SATA models)
6) Will you be overclocking?
Not planning on it, but if the hardware is particularly overclockable and I have the cooling to support it already, sure, why not.
3x1 1900x1200 initially. 5x1 1900x1200 eventually. Probably Dell 24" U2412M IPS panels.
Within a few weeks of finalizing the build list.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Crossfire support, USB 3.0, Wifi-g/n and at least one gbit ethernet port. Bolt-through cooler support. Raid 1 would be nice.
Yup. Have legit Win 7 x64 Home Pro and Ultimate keys coming out my ears (wife's a Microsoft Advisor at work).
