Waterhazard
- Sep 23, 2005
Any help would be much appreciated!
I'm not very familiar with raid setups but heres whats going on:
An old friend of mine set up a raid 1 mirror with two Western Digital Caviar SE16 WD4000KD 400GB 7200 RPM 16MB Cache SATA 1.5Gb/s Hard Drives with a DFI RS482 INFINITY 939 ATI Radeon Xpress 200 Micro ATX AMD MB for my father 2 years ago. It has been completely problem free until this week. It gives the error:
Verifying DMI Pool Data ..
DISK BOOT FAILURE,INSERT SYSTEM DISK AND PRESS ENTER
along with a $mft error.
I'm no pro but that mft error seems to be a very bad thing and I'm feeling pretty bad telling my old man that his plethora of family pictures that he holds so dear may be gone after assuring him that a raid 1 was the way to go.
Not knowing exactly how raid 1 works or if it mirrors the boot sector and file table, I switched the boot order to the other disk and just got an endless reboot loop.
I tried to plug both drives into another machine of mine and after a lengthly bootup process my comp will eventually hang before I can access the folders or run a scan or defrag while giving the "delayed write failed" message bubble several times.
In an attempt to just recover the data iff the disks I tried to boot to the XP install CD and run the recovery utility and about 1 out of 10 times I can get the machine to even recognize that the drive exists, but even when it does, it hangs endlessly at the first step.
I thought raid 1 was a foolproof way to at LEAST protect data. What am I doing wrong?
If ANYONE has any advice on how to recover his family memories I would be most appreciative.
