Help with creating my custom loop
blarf
Hi,
I've been reading on liquid cooling for a couple of days now.....but I'm still kinda confused/not sure on what to get.
I'd like a loop to cool CPU and GPU.
Case: Phantel Evolv ATX
CPU: Intel 6700K (Will Overclock)
GPU: EVGA 1080 TI Founder Edition (Will Overclock).
I'm looking for the best sound/performance ratio.
So far, I was think of the following (with the condition that it would fit in my case):
  • RADIATORS: EK-CoolStream PE 240 (front) and EK-CoolStream PE 360 or EK-CoolStream SE 360 (top)
Or maybe even a Black Ice® Nemesis® 360GTS® and Black Ice® Nemesis® 240GTS®
  • CPU Block: EK-Supremacy EVO
  • GPU Block: EK-FC GeForce GTX FE with backplate
  • Pump and reservoir or pump/reservoir combo....Not sure yet
Any comments or recommendations on what I would get so far?
Thank you
I've got a CPU+GPU loop in the same case, and here it is if you're looking for ideas.
There was some modding and some trickery involved in:
- The vertical GPU mount
- The rear 140mm radiator
- The DDC pump mount
The rest of it pretty much bolted together, and I got 140x3's worth of Swiftech radiator goodness in there.
