Help with building a pwner rig
piXel
A dude i know online needs a new rig.
The rig will be used for Gaming and server script benchmarks
It needs 8 gigs of ram, Quadcore Processor Preferabily a Q6600 I think which will be OC'D too 3ghz-3.2 ghz, Good aftermarket CPU cooler, graphics card will Probably be 4870x2, The case will probably be cooler master HAF 932.
He needs suggestions For the Ram,motherboard and PSU really, can anyone help?
Err, I'm sure you'll hear G.Skill and OCZ for ram, and Corsair 750w for the PSU.
Motherboard, there are a bajillion different kinds people recommend.
Please answer these questions or we cannot help you:
1) What's your budget? Are tax and shipping included?
2) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
3) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model.
4) What size monitor do you have or plan to have?
5) When do you plan on building/buying the PC?
G.Skill; Asus or Gigabyte P43 or P45; Corsair, Antec Earthwatts, Silverstone, or Seasonic. Many people can help. For better advice, answer Danny's questions:
Have no budget, don't want to go OTT but will fork out for the better component if needed.
Need everything from the CPU to sound card (the initial specified coolmaster case will be used)
No parts will be reused, I'm dumping this tractor.
I plan to get a 22-24"
Within the next 2 months
He just made an account so will post later
2 months? Then it's too early to start planning considering your friend's open budget and considering that Intel's Core i7 CPUs are being released next month. Whatever we recommend today might be outdated, outperformed, or out of stock as a result of the Core i7 release.
So find out what's your friend's actual budget because we cannot recommend parts well if there's no budget limitation. Also, find out for sure if your friend is buying witin two months or soon.
