Hey Guys. Its time for an upgrade and since I haven't kept up much with current hardware I would like some advice on what I should buy. I don't game as much as I used to but I would like a decent enough video card to be happy with most games and run two monitors and a TV for media. I would also like it to be as silent as possible.
It will double as an HTPC and my main gaming and work (coding) computer.
$1500 with tax and shipping but I would like to keep the price down as low as makes sense.
San Antonio, TX
CPU, RAM, case, motherboard, video card, SSD, bluray drive, case fans, CPU fan/heatsink
Brand new 650W SeaSonic PSU, two 3TB hard drives, dual monitors, and an HD TV
6) Will you be overclocking?
no
27" 1920x1080, 19" 1280x1024 (only used while coding), 47" 1080P TV (only used for watching media)
In a week or two
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
I need RAID 1.0 support for the two 3GB hard drives
No. I will need to get a copy of windows
San Antonio, TX
no
In a week or two
