Hey guys, recently I rebuilt my computer because I was having issues with CPU temps. I also bought a antec 920 to install when I rebuilt it. Ever since I did this I have been having booting problems.
The computer only has these problems when it has been turned off overnight, whereas if I just turn it off, then back on 5 minutes later, it will boot with no problems. This made me think that the CMOS/BIOS battery might be faulty, so I replaced that and it didn't fix it.
So with that possibility eliminated, I thought maybe it wont start because the fans are lacking RPM, so I disabled the smart fan option and still it wouldn't work.
The ONLY way I can get this thing to work, is to take out the CMOS/BIOS battery and reseat it after waiting a few minutes. Having to do this every morning is a PITA. After reseating the battery and booting, it is stable and doesn't crash or bluescreen.
At this stage I am thinking maybe the motherboard is faulty. This has me stumped, because everything runs without a hitch when I finally get it working. I would be grateful for any help or pointers on this subject.
System specs: (everything at stock clocks)
Gigabyte G1 Guerrilla
i7 960 3.2ghz
6GB Corsair Dominator RAM
Asus 560TI
WD 1tb HDD
i7 960 3.2ghz
Asus 560TI
WD 1tb HDD
