Help with an upgrade decision
jordan12
Ok, My current specs is the
E8400
4 gig ram
etc
I have been looking at a new video card. I have a 4870 in there now.
But I am now thinking that maybe a new MB, CPU and RAM might be a better choice..
I can throw maybe 400 bucks total into it. What would you upgrade with that amount of money?
Or maybe not upgrade at all...I do play some games. Like Dragon Age 2 type games.
I do some video encoding as well so that I can transfer movies to my nook...
So advice?
need more info. Please answer the stickies first.
Wrong subforum there hossdaddy :)
Jodan, it would help if you answered the following questions:
3) Where do you live?
6) Will you be overclocking?
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
I live in olathe. Kansas
I am looking at a new mb, cpu, and ram
I will reuse the rest. So only three parts above are being replaced
My psi is a coolermaster 1200 watt silent pro series
No overclocking
My monitor is a 28" running at 1920x1280
Looking to get parts now
For the motherboard my big requirement is that is has at least 8 sata ports
$360 - Intel Core i5-2500K CPU + Asus P8P67 Intel P67 ATX Motherboard Combo
$41 - G.Skill Ripjaw Series F3-10666CL9S-4GBRL 4GB DDR3 1333 RAM
Total: $404 plus tax and shipping
That mobo is the cheapest socket LGA 1155 mobo that I could find that had 8 SATA ports.
And I would assume then that this option would be a much better performance option than my current E8400?
Figured I would chime in here
Danny helped me with my upgrade choice before a few months ago, hes a good person to follow for advice
I have a E7400 and had a GeForce 6800 series.
After much debate, I decided to upgrade the card to a Radeon HD 6850
Things seemed more fluid, but it was still missing an oomph for me on the upgrade
So I plan on now getting a 2500k, new motherboard, and new RAM which will probably do the oomph I was looking for back then.
