Help with an endless boot cycle
ChwyNiblet
I just wrote this at OCN but I'm strapped for answers and wonder if anyone here could help me out.
So I'll try to be as clear as I can with this, but I'm beyond the point of frustration. ::deep breaths::
Today I bought a Corsair H60 cooler to replace my CM 212+. Opened up the case, took out the rear fan and the front fan that came stock with my CM Storm Scout case. Took out the 212+ and installed the H60. Things went without a hitch. Went to start up the computer and I was greeted with no video coming out and the computer rebooting every 3-5 seconds.
Heres what I'm working with:
Gigabyte P55-UD3R Rev. 1
Core i5 750
GeForce GTX570
Now I should preface this with this bit of unclear information. Before I installed the H60, I started my computer, walked away for a little bit then when I came back glanced at the screen and saw I message saying something to the effect of "The computer can not be turned on because the overclock was deemed unstable" or something to the effect of that. I just quickly disregarded it and shut the computer down to do surgery.
So the confusing thing is the motherboard doesn't seem to know whats wrong with itself. Sometimes I get very fast continuous beeps (power issue) and sometimes I don't get any beeps and it just reboots. Sometimes when it reboots the fans on the cooler and GPU go to full blast and sometimes they don't. Its rather confusing.
The first thing I did was swap out the PSU. That didn't help, same exact issues. Then I tried switching out the GPU, that didn't work either. I tried booting with only one DIMM in the first DIMM slot, that did not work either. Unplugged every unnecessary connector on the motherboard (front audio, USB ports, etc..) that didn't do anything. I reset the CMOS both by jumping the CLR_CMOS pins and taking the battery out for 2 minutes. I didn't remove the CPU from the socket so I doubt it was damaged when I replaced the coolers, I just rubbed it down with rubbing alcohol to get the old thermal compound off. I don't think the motherboard is shorting on itself but I haven't taken it out of the cast yet because what would it be shorting on? I just replaced the cooler and it was fine before I switched them out. Tomorrow I'm going to throw it on a test bench and stick the stock CPU cooler on the thing to see if that works.
Do you guys have any ideas? I'm kind of stumped here. Any help would be appreciated. Thanks!
For a quick fix try this, loosen the H60 cooler screws a 1/4 turn - 1/2 turn on all 4 of them. The CPU and mobo pins could be not properly aligned if the cooler is too tight. This happened to me and caused me headache just like what you are dealing with now. I hope this helps.
This is a common Gigabyte problem. It's not a reflection on your parts really. I have a Z68XP-UD3P and I've spent so long dealing with boot loops. There are a number of issues that you should try. Using one RAM slot has helped some people, but you've tried that. For me the issue turned out to be using video cards in crossfire, and when I just used one card or used the integrated card my board was fine. Disabling PLL overvoltage has helped some people.
I used to spam the reset button when the computer turned on and eventually it would POST successfully. Sometimes unplugging it from the wall, then clearing CMOS will help.
Check this thread to see what a lot of people have said about this issue.
http://forums.tweaktown.com/gigabyt...boot-loop-problem-hitting-p67-z68-boards.html
Core i5 750
GeForce GTX570
Have you tried to change your power supply?
Mostly the power supply is the root cause of the problem as I have experience this on my side.
If you can still enter bios, try to update bios to latest F8.
http://www.gigabyte.com.au/products/product-page.aspx?pid=3162#bios
I ended up fixing it. It would boot with both sticks of RAM individually but not together when they were in triple channel. Somehow their voltages got lowered in the BIOS causing the computer to go into constant reboot. Very very weird, but its fixed now. Thanks everyone for the suggestions!
