hawkeye_wx
- Oct 20, 2008
This build is for my Mom and will replace her ancient Athlon XP system. This system is used for typical mom stuff... email, web browsing, etc. She does not play games or watch movies. I just want the new system to be nice and snappy with smooth browsing and hd video playback(youtube videos, etc).
I don't have a fixed budget. I just want good bang-for-the-buck parts for a solid basic build.
Iowa, USA
CPU - I had considered a Pentium G3220 for ~$60, but I can get some better cpus at a good discount. Here are my three options... unfortunately, no mainstream(no-letter) chips.
core i3 4130T ($61) - 2 cores, 35W
core i5 4570T ($97) - 2 cores with enhancements, 35W
core i5 4690S ($111) - 4 cores, 65W, great deal but may be overkill for my mom
Here's a side-by-side comparison chart http://ark.intel.com/compare/77481,75045,80812
GPU - Intel integrated gfx should work well, I would think
Mobo - I've been out of the loop for a while, so I'm not sure what the most reputable brands are now. It appears the H81 chipset is the least expensive, so is that a good one for this basic build?
RAM - This is going to be my mom's computer for 7-10 years(hopefully), so I was leaning toward 8 GB, but if she'll never use more than 4 GB then that could work as well. I'm not sure.
SSD - Would like to get a good deal(<$100) on a 250/256 GB ssd this holiday season... leaning toward a Crucial MX100, or a Samsung EVO.
DVD - She rarely uses her current dvd drive, but it's an old IDE model. I think the new system would require a SATA drive.
PSU - Her current system uses an old Antec 350W with a loud, past-its-prime fan. I was thinking something like an Antec Earthwatts 380D or Corsair CX430 would be good for her new system. Any preference for one of those? Or is there a better choice? I don't want a cheapo unit, but don't want to spend a ton, either. Obviously, this system will be pretty low power.
Speakers - This isn't an immediate priority, but she is still using the crappy speakers that came with her first HP computer in 1997. I'd like to get her something decent at some point. I don't think she needs a subwoofer, just some nice sounding speakers that can sit on her desk next to the monitor.
-case - I figure I can save money by reusing her old case with 2 x 80mm exhaust fans
-ps/2 keyboard - it's very old, but still works fine
-cheapo speakers (came with HP system in 1997) - I need to upgrade her audio to something decent one of these days
-mouse - she just bought a wireless Logitech
-fan controller - a Sunbeam, currently used for two case fans and a cpu fan
-usb hub
6) Will you be overclocking?
No
22" Acer LCD, 1920 or 1680 res
Soon. I've been waiting for the typical November(black friday) deals.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Her old keyboard will require a ps/2 port. I suppose USB 3.0 would be a plus for the long term. Otherwise, whatever is necessary for a basic haswell system with integrated gfx.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I'm thinking she could just keep using her retail copy of Windows Vista 32-bit for a while and then pick up a copy of Windows 10 later next year.
Iowa, USA
-usb hub
No
