Help with a new 2014 build...
Etherton
Will Bang for Poof
Looking for a little help with a upcoming build. I have not built anything for about 5 years now - i7 920 was my last build. Thanks for any help!
Photoshop - RAW files, Gaming (love to crank the settings to the max) and web browsing.
$2000-3000
Western KY - No microcenter close but would be willing to drive to STL if it would save some money.
4) What exact parts do you need for that budget?
CPU & cooler
Motherboard
RAM - lots
GPU - really considering going SLi or Crossfire with this build
SSD - 256gb
HDD - 2x3TB?
PSU
Case
BR Drive - preferably slot drive
5) If reusing any parts, what parts will you be reusing?
Speakers, Headphones, Keyboard & Mouse
6) Will you be overclocking?
Probably but was hoping I wouldn't need it right away.
2560x1080 - LG Ultrawide 29" 21.9
March - April 2014
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)?
UEFI? etc.
I was hoping you could help me out here.
Windows 8 - 64bit
I would wait until you're closer to that time frame. Anything we recommend will likely come down in price or be replaced with something better/newer by that time.
Pretty much what Priller said: Your best bet for a solid and up-to-date build list is to wait until you're 1-2 weeks away from buying the parts and then ask for advice.
