Help with a build?
GooG
Im looking to build a system soon, i will be doing some video editing, dvd burning (burner to burner) picture editing, and some game play. I plan on later getting a blu-ray player and a 28" monitor. But for now its a 19" crt. I have nothing that i will be using from a previous build, except an 80gig ide hard drive, but i might make that external. Budget.......
If you want us to help, answer these questions:
  • What is your budget? Are shipping and/or taxes included within that budget?
  • Where do you live? Where are you (planning on) buying everything at?
  • Which components do you need to get? Which components do you already have? Which components are you going to reuse (from older builds)?
  • What are you going to use your computer for? Which games/programs are you going to use?
  • Do you plan on overclocking? Are you going to use water (or some other form of "exotic") cooling?
  • Which monitor are you using? What resolution do you use? Are you using multiple monitors? Do you plan on buying a new/multiple monitor(s) any time soon?
  • Which features do you want on the motherboard?
  • How long do you want this system to last? Are you (planning on) making any incremental upgrades during that time?
Also, look around the Gen Hard forum. More than likely there's at least one thread that matches your requirements and budget posted within the last week or so.
* What is your budget? Are shipping and/or taxes included within that budget?
* Where do you live? Where are you (planning on) buying everything at?
* Which components do you need to get? Which components do you already have? Which components are you going to reuse (from older builds)?
* What are you going to use your computer for? Which games/programs are you going to use?
* Do you plan on overclocking? Are you going to use water (or some other form of "exotic") cooling?
* Which monitor are you using? What resolution do you use? Are you using multiple monitors? Do you plan on buying a new/multiple monitor(s) any time soon?
* Which features do you want on the motherboard?
* How long do you want this system to last? Are you (planning on) making any incremental upgrades during that time?
Most of this was answered in the first post but...
1) open budget but i want it to be as low as possible.
2)newegg/online
3) need all
4)photo/video editing, dvd burning, games at decent resolutions... Not looking for the best.
5) yes i will oc some.
6)monitor 19" crt will buy a 30" or so in the next couple of months, will upgrade video card when i do
7) everything i need, not looking for specifics..
8)as long as possible, will upgrade as needed.
You really need to give us at least some idea of how much you can spend. For some people around here a statement like that might mean anywhere between $2000 and $3000, to others it might mean between $500 and $800.
just like it says lol.
lowest as possible, closest to 1$ as possible.
Dell Vostro 200, $400 for 1.8Ghz Dual Core Allendale, 1GB RAM, 160GB HDD, DVDRW SATA, microATX case, 300W ATX PSU, onboard Intel GMA 3100, 20" widescreen LCD, Windows (Vista Basic or XP Home), and 1yr warranty.
Or...
Check gotapex.com for some dell deals. Many desktops they have can be upgraded with an aftermarket 9600GT.
http://www.gotapex.com/ said:
This is the best desktop deal going on right now at Dell. For $499 after $260 instant discount, you get an Inspiron 530 mini desktop with:
  • 2.4Ghz Core 2 Quad Q6600
  • 3GB DDR2
  • 500GB HDD
  • 16x DVD+/-RW double layer burner
  • 1 year warranty
  • Windows
This is set to expire on 11/19/08 at 11:59PM CT:
* With Vista Home Premium: DELL INSPIRON 530 VISTA DESKTOP DEAL
* With XP Home: DELL INSPIRON 530 XP DESKTOP DEAL
$150 - eVGA 512-P3-N861-AR GeForce 9600 GT 512MB ($10 MIR)
There are more dell deals, too.
Abu... where are you? I need you to beat those dell deals with custom builds. ;)
Here ya go:
Intel Core 2 Quad Q9450
G.Skill 4GB (2 x 2GB) DDR2-1000MHz RAM
MSI Neo2-FR P35 motherboard
Corsair VX550
Xigmatek HDT-S1283 heatsink + bolt on kit
Antec Solo Black Mini-Tower
Yate Loon D12SL-12 120mm Case Fans
ATI HD 4870 (will be out soon)
640GB Western Digital Caviar SE 16
Samsung Super-Writemaster SH-S203D
Windows Vista Home Premium 64-bit
