Help with a $600 build.
vict0r
Hello guys,
it is tough for me to decide what to pick and what not. i dont know which route to go.
however, i'd like to stick with Intel. i3,i5, or i7.
its the case only, no monitor included in the $600.
thanks!
Needs to handle modern games like bf3, upcoming mw3 , cs go etc etc, and basic daily stuff, web browsing, youtube, watch movies, stream movies,
$600 shipped to 33186 from amazon.com ...
i live in the caribbean, however i order from amazon, they get shipped to an address in miami and get here by seafreight.
Mobo,Cpu,Memory, Graphics Card, PSU, DVD RW , HDD, CASE
none, everything new
6) Will you be overclocking?
if possible yes, why not? it'll be a bonus
i think ill get a 23" 1920x1080 locally
as soon as i gather enough info
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support?
none, needs to be simple..1 dvdrw, 1 hdd, 1 videocard, 1 powersupply, 2 memory sticks in a case.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I will be using home premium 64bit
so I'm in a similar boat, system a little older than your current one, and looking at upgrading.
Here's the deal, it's a tight budget.
If you throw money towards the chip, you're looking at about $100 vs. $200 vs. $330 for i3 i5 i7.
To me, it's worth the coin to go for the i5 2500k, see what you can hit with the stock cooler, should be a 1ghz OC minimum.
As far a video card, if you're planning on doing gaming, you'll get the most bang for your buck here. From all I've been reading, I'd try to grab a 6950 that you can unlock the shaders on, if not full flash to 6970. $230ish, maybe more
I'd go with 8gb of decent ram, even 16gb. Anymore it can be had for cheap. I'll say $60
A mobo can be had for $100, but for a great one you're talking $150 to $200
So already you can see you've got a problem, a quality PSU (you'll need it) and case is going to set you back another $150 (I think).
You can get a 1tb or 2tb drive for $50-$100, figure $30 for a DVDRW
I think you can see we're going to have a problem with the budget.
Either way, the Z68 ASUS boards look solid, especially for OC'ing
Recycling parts is going to save you $$$ if you can...
Your pricing here is a bit off: The floods in Thailand has lead to a hard drive shortage and therefore increasingly high prices for hard drives. It's now ~$150 for a 1TB drive and $220 to $300 for a 2TB drive.
Anyway, vict0r, here's a build:
$125 - Intel Core i3-2100
$60 - MSI H61M-P21 Intel H61 Motherboard
$44 - Kingston Hyper KHX1333C9D3B1K2/8G 2 x 4GB DDR3 1333 RAM
$150 - Sapphire Radeon Radeon HD 6770 1GB PCI-E Video Card
$100 - Western Digital WD5000AAKX 500GB 7200RPM SATA 3.0Gb/s Hard Drive
$22 - LG iHAS124-04 DVD Burner
$58 - Corsair CX500 500W PSU
$50 - NZXT Source 210 Elite Black ATX Case
Total: $609 shipped.
It's over budget but worth the extra cash for it IMO. I highly recommend NOT picking up a 1920x1080 monitor as the above build is not suitable for 1920x1080 gaming unless you don't mind low-settings across the board. Stick with a monitor with a resolution under 1920x1080 and you should be fine with the above setup.
What about a 6850 or a 6870 video card? They are around the same price point of the 6770 you have in the above build (6870 ~$170)..
hey thanks Danny!
the Samsung F3 went from $70 to $150 meng !
wow
i think he linked a 6850 but wrote 6770 ... if you click itll bring you to a saphire 6850
hate to thread jack but would that be suitable for gaming at 16x12 rez? and would settings be ok at high? im in a similar boat as the OP budget wise.
Is there anyway you could reuse your PSU, case and Hard drive?
no,it has to be a complete new build
would it be ok with danny's build, instead a 20inch widescreen?
As vict0r pointed out, I listed the wrong GPU but linked the correct GPU.
I can't vouch for the settings to be high but it'll provide at least mid settings. With that limited budget, you really can't expect high settings.
2500k - 220
p67mobo - 150. newegg combo discount will save you $20 on top of that.
8gb ddr3 ram - 50
aftermarket cooler - 20-100
not enough for a new graphics card though. :(
