Okay I got some big rar files ( +2 GB), and my C: on this computer is 6.2 GB with only 1gb free hdd space.
So when I extract it, it goes to my C:\Documents and Settings\Darryl\Local Settings\Temp
Is there anyway to change it from always going to that temp folder?
I've gone through the Winrar options to paths tab -> Folder for temporary files is set to E:/Temp
But that doesn't seem to change anything, it always goes to the Local Settings/Temp, and I watch my hard disk ( C:\ ) go critically low on disk space.
Any help would be GREATLY appreciated. I would prefer a work around, or even alternative software that would do what I told it to.
Thanks
Darryl
Comp Specs are:
Windows XP Pro SP2
AMD 2500 XP-M
DFI NFII Ultra B
C: 6.2 GB (windows drive)
D:160 GB
E: 200 GB
