If you're gonna ask us to build/list a PC for you or seek advice about a build, please answer all of the following questions:
1) What will you be doing with this PC? Vm ware probably 4 at a time 1 gig assigned to each at once, and then gaming on the side (sc2 , wow, diablo3, civilization)
2) What's your budget? Are tax and shipping included? 1500-1600
3) Which country do you live in? If the U.S, please tell us the state and city if possible. Corpus Christi , Texas
cpu , ram , video card, case, power supply, optical drive, cooling ..
One monitor , keyboard, mouse, external hdd
6) Will you be overclocking?
very lightly if I decide too
22" lenovo , will probably pick up a second one for the build.
Whenever I get the pieces all together
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
just 24gb ram capable incase I need to upgrade, and sli ready
Yes , Windows 7 pro 64bit
I prefer intel , but I am open to what amd has to offer.
