VoodooChi|d
- May 3, 2005
Ok so I re-installed XP and re-installed the 5.6 drivers and now theres vertical lines scrolling downwards on my monitor... changing the refresh rate just makes the lines closer together or move faster but they're still there... I tried wiggling the cable but that didn't help.. BTW my vid card is Dual DVI and right now im on a CRT monitor so im using a DVI to VGA adapter... I don't have any other monitors to test if it's a monitor issue or any other VGA cables to test if it's a cable issue... I'm ordering a 2005fpw once they go on a good sale again... but I'd rather be able to figure out if something needs to be RMA'd soon... Also I used driver cleaner and got rid of the drivers and re-installed but that didn't help either...
Any thoughts?
Any thoughts?
