Help, think I bought a lemon....
epicstruggle
Hi,
I got a Intel 980x cpu from work and bought the following from newegg:
GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
and paired it with 12 gigs of ram:
OCZ Reaper Edition 12GB (3 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Low Voltage Desktop Memory Model OCZ3RPR1333C9LV12GK
The motherboard doesnt recognize all 12 gigs, usually 8gigs and a few times all 12 or 4gigs.
Had Gigabyte RMA me a new board (through newegg) and now the same thing with the memory, but also the CPU only gets recognized as a 2 GHZ cpu.
Help, what the hell is going on? Did i just get 2 duds in a row?
Let me know if you need any additional info, thanks for any and all help.
Yeah, flashed it early on. Both MB's had the FA bios and I got the latest from GBs website. did not fix a thing.
what heat sink you using maybe a problem possibly flexing the board. But honestly it might just be you need to manually set youre timings right on mem turn all the powercrap off in bios see if that helps. On my ud5 with newer bioses I can actually make it only show 2 gigs all the time Just by changing the timings on the memory.
The heat sink is stock intel. Im pretty sure i havent flexed the board. (or i hope so.
for the manual timing issue, what are good values to run at? Will try turning all the power settings off. will get back as soon as dinner is done.
