help...temperatures are high....
I have DFI lanparty UT nF4 Ultra-D motherboard. I recently updated my bios and installed opteron 165. After I installed the processor I checked the temperatures for my motherboard, chipset etc... here's the problem. According to everest and speed fan, my motherboard temperature is around 46C idle my chipset is around 50-52C idle and my processor is around 48C idle.
What's going on with my computer????
the bios might be overvolting your processor , or you didn't mount your hsf properly but that wont make your northbridge go up.
You have new settings from your bios now and your cpu might be a newer cpu with a smaller fabrication size and there fore needs less voltage.
Best is to tweak everything yourself , like set the right Vcore and MCH. Most of the people who overclock cpu's manage to get about 400mhz without even increasing the voltage.
Try and find your right voltages by lowering them and see if they are stable by running prime on it.
airflow's fine. I had 3000+ before I switched to opteron. Temperatures were 33C ilde for the processor 45C for the chipset and 43C for the mobo. I checked the bios and it wansn't overvolting. I loaded default settings couple of times but no luck.
your last cpu may have needed the Vcore what your BIOS has it as but your new cpu will be better and efficient technology and may use less Vcore.
Decrease it a notch and you will start to see the temps go down.
This happened to me on a venice core 3200 and the Bios vcore was quite high and was at 1.54V , i then reduced it and found its best Vcore at given speed which was 1.4V
Now you can see what difference this will make to the temps. Your BIOS has the average Vcore for some CPU's , now if you choose a cpu which uses less Vcore , your BIOS will then not change its Vcore.
Every CPU is different and finding its optimum is called tweaking and thats waht PC technicians and overclockers to get the best settings out of the components he or she has in front of them.
There is so much you can tweak and it makes soo much of a difference.
What is your Vcore anyway?
after that compare it with people on the leaderboard and you will see a pattern of what yours would be best at.
i think its your IHS and it isnt making good enough contact , this is a tricky one , you can lap the hsf and the cpu but lapping your cpu will void your warranty.
The new bios might have recalibrated the temp sensors. Not sure what your old version was, but you could always try flashing back to that one if it supported dual core and see.
