Help Selecting the Best Micro-ATX Tower?
Sob Rogue
I'm looking to get a Micro-ATX case for my bro. After looking around I wasn't too impressed with what I saw. The best thing I found was the Apevia X-QPack2. I really like the portability and design. But the quality seems to lack, I'm looking from somethings thats rock solid and won't break when u sit on it. You know, like they used to make them...if they still do.
Thanks
I'm confused.. your thread title says "tower' but yet you mention a cube case? which is it?
If it's a cube you're looking for then I can reco the Antec 1300/1380 or of course the Mini P180 for a MicroATX Tower style case
Im sorry, I was leaning towards the cube. But I'm just really looking for a good micro-atx case over all.
Don't consider the Apevia. It comes with a shitty PSU. The fact that you pay for that PSU when you buy the case is kind of stupid IMO. Check out the Ultra Microfly. It's a bit longer than the Apevia case but they have the exact same layout and construction. Though I'd give the Ultra the slight edge here since it comes with a semi-decent PSU.
You might want to check out these other cases as well:
Silverstone SG03-B mATX Case - $135
NZXT Rogue mATX Case - $150
