- Jan 15, 2005
ok, so im postiing here for some help on my new build..
specs: fx-55
Dfi-ultra-d
1gig OCZ memory
x800xl
WD sata 10K raptor 74gig
Win XP Pro (OEM)
now....
i can look in my BIOS settings, and it recognizes the hard drive, but when i go to install the Win XP, it says that it cant recognize the HDD, and when i hit enter to install, it blue screens...
now, i have these drivers on the floppy that came with my Mobo..
now, i have looked in the FAQ, and these are the exact instructions..
How do I create SATA RAID on LP NF4 series boards?
Answer:
SATA RAID building is a bit complicated on this series board, because NF4 chipset provides multi functions, e.g. SATA and IDE hard disks can be combined together to build RAID, such as Mirroring (RAID 1), Striping (RAID 0) and Stripe Mirroring (RAID 0+1) simultaneously. Please refer to the setup procedures below.
1. Enable SATA RAID in BIOS.
2. BIOS >> Integrated Peripherals >> RAID Configuration.
3. Enable the hard disks expected to be created RAID in here, save, exit, and then reboot.
4. Hit "F10" to enter RAID BIOS when the RAID detecting screen appears; follow the hint bar in the bottom of screen to create RAID. Finish setting, hit "Crtl + X" to exit RAID BIOS.
5. Hit F6 immediately when Windows Blue Setup Screen appears and put the RAID utility diskette into floppy.
6. The following step is extremely crucial, there are two essential files must be installed. Please hit "S" for installing one RAID driver, and then hit "S" again to install another one. Please be sure both of them have been installed completely, or Windows Setup will be failure with RAID.
7. After installing operating system, just check the partition in hard ware management if it is correct or not.
Please treat hard disk cables as extreme caution while creating RAID, if one of them is breakage, the operating system will be messed up. And it will not boot again, all the data in the hard disk will completely disappear. No save ways available to recover back.
now, i have tried these steps, but once i get to the 4th set, and try to hit F10, it doesnt go to the raid set-up BIOS...
now, my question is:
do i need to buy a controller card?
do i need to buy a non OEM version of XP pro?
or, do i need a new HDD\mobo?
specs: fx-55
Dfi-ultra-d
1gig OCZ memory
x800xl
Win XP Pro (OEM)
now....
Answer:
