I'm sure several of you have built many more PC's than I have, so please lend me your wisdom and teach me the ways.
- Mostly a gaming PC with some work thrown in
- Budget unlimted within reason
- United States
- CPU, GPU(S), RAM, Cooler, SSD's, MB
- Reusing case - Cool Master HAF with glass window (Best Case ever)
- Overclocking , not really but maybe on the CPU a little
- Monitors 3 28" monitors I want to run everything in 5xxxXxxxx resolution 2D
- New PC - Ordering Parts as soon as enough say ya or na
- MB Features - Would like dual 16x16 pcie slots
- Yes Windows 7, 64BIT
Here's what I've spec'd out after weeks of research, any suggestions or anything you might do different?
MOTHERBOARD
Asus Rampage IV Extreme , has dual 16x16 and allows for tri sli at 16x16x8.
It was a tossup between this one and the ASRock Extreme 11 which allowed 16x 3
CPU
Intel I7 - 3930K Sandy Bridge-E : Given the extra horsepower under the hood it
seemed like a no brainer over the 22500/2700 + OC'ing to 4.7 on air sounds easy
CPU COOLER
Noctua ND-H14 . I've got a ThermalTek V1 now, but I've read Noctua is about the best
Memory/RAM
G.SKILL Ripjaws X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133
I was unsure if Ripjaws Z would be better being for the X79 specific but everything I
could find says stick with the X even on X79 socket 2011
GPU
2 EVGA GTX 4GB SuperClocked 670's.
SSD
1 Samsung 830 series 128GB for OS
1 Samsung 830 series 256GB for games (example Shogun which is so slow to load
onan HHD)
Question - I don't understand SLI and video memory. If I get 2 cards and SLI them it won't give me 8GB, the cards split the memory and continue to use 4GB .... but why does performance in games increase so much then if it's still the same amount of memory. How is the 2nd card in SLI helping?
Thanks a bunch.
- United States
MOTHERBOARD
CPU
CPU COOLER
Memory/RAM
GPU
SSD
onan HHD)
Thanks a bunch.
