Help recommend a decent standalone USB mic
Zarathustra[H]
Extremely [H]
Hey all,
Instead of a headset I use a separate set of headphones and a standalone mic. My can recently chewed up the cord of my existing cheapo mic, so now I have an excuse to replace it.
I've decided that I am giving up on the mic port on my Sound Blaster Titanium HD. It rarely seems to work properly, and when it does its only after a lot of tinkering and plauying with driver settings. (Creatives drivers are terrible!)
Because of this, I have decided to go with a USB mic this time around.
I'm thinking I'd go for something just above regular desktop mic quality, but nowhere near studio mic quality. (no need for phantom power for me :p )
My budget is $50 or less
What do you guys think?
I found the Samson Go Mic online which looks OK, and kind of in the range I am looking. Are there others I should consider?
Thanks,
Matt
I swiped the USB mic from a rock band game for ps3 and made a mic stand for it. It's an unbranded logitech mic. Works great and didnt cost me anything since i already had it.
Hmm..
At $60 on Amazon, maybe I'll spring for the Audio-Technica ATR2500-USB. A little more than I was planning on spending, but it seems like a lot of bang for the buck
