help. QuietNCool not working on A8N-VM CSM
I recently put together the following and cannot get the Quiet N Cool to work without locking up Windows XP on load.
- A8N-VM CSM rev 1.01, bios 403
- cpu: AMD +3200 Athlon 64 cpu
- ACPI 2.0 Support - enabled in bios
- ACPI APIC Support - enabled in bios
- AMD Athlon™ 64 Processor Driver for Windows XP and Windows Server 2003 Version (exe) 1.2.2.2 installed and showing as driver version of CPU in device manager
When I enable "AMD Cool 'N' Quiet Configuration in the bios, as windows is loading, it will lock up.
So it's either
A) cpu driver 1.2.2.2 isn't right for my mobo?
B) Asus A8N-VM CSM requires a bios fix?
C) I'm doing something stupidly wrong, and deserve a beating?
I contacted Asus support and the guy explained that Q-FAN only spins down the fan based on temperature. Which is true, except I'm trying to get Quiet/N/Cool to work and not QFAN.
Anyone out there with an A8N-VM CSM get QnC to work?
It's still pretty new...might need a bios revision to get the quirks with CnQ worked out.
Does anyone else have the A8N-VM CSM motherboard, and has gotten Quiet N Cool to work?
rev 1.01
bios 403
cpu driver 1.2.2.2
WinXP SP2
AMD has the mobo certified to work on their website.
Asus support is clueless.
Confirmed it's a bios issue.
beta bios 502 fixes QnC, but screws up the PCI slots.
hopefully an official bios update soon
LOL...always hate being a bios guinea pig for Asus :rolleyes: (or MSI in my case :) ).
BIOS 0506 is now posted at the Asus download site.
Usage:
AFUDOS /i0506.rom
1. Fixed can not use HD security after resume from S3 mode.
2. Improve Cool'N'Quiet function.
3. Patch some ATI card cannot display
4. Please do not update this BIOS via EZFlash. Must update it via AFUDOS or ASUSLive Update.
