Help quiet down my gaming PC
Hi forum,
Looking to quiet down my gaming PC, which generates a lot of white noise. I'm particularly looking for suggestions on a solid chassis and fans that move a lot of air but still keep things cool. Also, I've got a Galaxy GTX 480, would swapping to a GTX 560 (or 580?) help quiet things down?
PC games (Minecraft, Skyrim, TF2, Killing floor)
Web browsing, general office tasks, programing.
Video conferencing (Skype, Google talk).
About $800 USD, with good justification up to $1000 USD.
San Francisco Bay Area, California.
A solid, well constructed chassis that is quiet but moves a lot of air.
Mabye a new video card if the Nvidia 5xx series is significantly quieter than the GTX 480 I've got.
Potentially a new CPU cooler or even water cooling.
I've got in the system now (and willing to reuse all/any):
Gigabyte GA-X58A-UD3R
Intel i7 930 @2.8GHZ
12GB (3x4GB) of DDR3 memory
Intel 600G 320 SSD
1TB WD black (FAEX) drive
Galaxy GTX 480
6) Will you be overclocking?
Not likely.
Its a Dell 2707WFP, 1920x1200 27".
Early December.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
I'll probably reuse the mainboard I've already got.
Yep, I've got Windows 7 64-bit licenses.
Thanks!
You know, it would help to include the power supply: PC Power & Cooling Turbo-Cool 1KW. This guy works well but probably generates a lot of noise too. So maybe a power supply replacement would be a good idea to add too.
The key to quiet computing, is having big fans that spin slow. Look for a case with big fans on the back and top. Also look for after market cooling for your cpu and your GTX480.
The above should quiet your PC considerably.
But the Raven is so.... ugly. :p Go for the FT02 if you're like me and prefer a much cleaner looking case. ;)
What's the voltage of the DDR3 RAM you have now?
From the SPD data (acquired via cpu-z) its 1.5v, Micron Technology DDR3. I can find the exact modules on Crucial's web site if you need more information
Honestly, you might be fine with just a new case. Read this article:
http://www.hardocp.com/article/2010/09/30/my_quiet_galaxy_geforce_gtx_480_sli_build
I saw that article when it came out. Its a neat idea but it may not work in my setup. I often have portable hard drives that sit on top of the chassis and having cables that protrude from the top would make that not possible. Also, my cat likes to sit there, its her butt warmer.
... I often have portable hard drives that sit on top of the chassis and having cables that protrude from the top would make that not possible.
On the FT02, there's a grill there that covers all the cables and actually channels them towards the rear of the case; so you'd still be able to put your drives and cat on top of it. ;) (I'm assuming the Raven also has such a cover)
Alright, I think I'm going to try swapping the build into a LIAN LI PC-V1020B case. Thanks everyone for your input on this question!
