HELP! Q6600 Stock Cooler Temps
amorak
Hey guys,
I have built a tonne of AMD systems, but this is my first intel build and my first time using a stock cooler.
Some background:
- I have an Antec Solo Case, with 120mm, 64cfm intake and exhaust fans.
- I am running the stock cooler, with AS5 applied in my normal fashion.
Anyways, I am getting high 50's celcius idle tempuratures, and about 80C after 3 hours of priming all four cores.
What's the deal?!
FWIW, speedfan shows my case temp as 48C...
A picture of coretemp for reference:
My guess would be that much overclocking and especially increasing the voltage on the stock cooler is probably a bad idea, but even then I'm surprised by the temperature. I have found that higher Vcore causes huge increases in heat though?
I don't understand :confused:
Are you saying you are surprised by those temps on an overclocked cpu with the stock cooler? If so don't be because they are right at where they should be.
Yeah, I got high 40s idle and 70-75 with about the same OC settings on stock cooling. Not too far off.
I wouldn't be comfortable with how high it's getting on load myself, though.
I probably should have used CoreTemp on my newly-motherboard-swapped system before I pulled my Q6600's stock HSF (which I broke a tiny piece of plastic on, which meant one of the pushpins would no longer seat properly--I didn't even realize this until an hour ago, which sucked). My P35 Neo was reporting its temperature at 58C, case open. $46, some Antec Formula 5, and a Thermaltake TMG-I2 later...it dropped like a rock to 16C in the BIOS (and slowly crawled up to around 22C)--but CoreTemp currently shows all four cores at around 50C, minimal load. Then again, I do have to wait for the thermal goop (damn, I forgot the new HSF came with its own paste in place) to "settle," right...?
