Okay so, this is possibly the worst and most random thing that could happen... I had a glass of pop sitting on my desk, and one day while I was gone my cat knocked it over, it spilled off of my desk, and into the top of my case where there is a huge fan (I have an antec nine hundred case). The pop was then sprayed all throughout my case since it was running when this happened... It was turned off when I got home and I just pressed power to turn it on when I saw that it was off, thinking there was just a brief power outage or something. It made a zap noise and would not turn on (that's when i noticed the drink had been spilled). So after all this I guess my question is... How do I know which parts are bad and how can I test them? When I plug the power in, the blue LED lights turn on, leading me to believe the power supply is still good. I get a blue light on the motherboard and if I try to power on, a yellow light appears on the mobo. Any help you can give me would be greatly appreciated. I built this cpu about 3 months before this happened and it was a HUGE upgrade to what I was using... I would love to get it back up and running!
