Help plz
pffff
so i ran OCCT and went and took a nap
when i came back my screen was off and my computer had shut it self down upon trying to power it on it stuttered as if it werent getting any power .
the leds on the motherboard / fans etc all flicker on then off
i tried my back up Psu since i thought it was my cheap power supply so upon hooking it up got the same thing
weird thing is when i only plug the 24pin atx cable in and not the 4 pin 12v it powers on but i still get no video when it powers on even trying the onboard vga
when i plug in the 4 pin 12v it stutters and the leds / fans flicker like there not getting power
i tried taking all other things out Vga , ram, hd
i moved my entire setup to my other comp and it booted right up with my video card so i ruled that out
also everything is water cooled and the pump is still working and everything is flowing fine
motherboard is a
Biostar Tf7025 with Amd x2 6000
im guessing my motherboard is dead?
can this be because of my proc which i hope it isnti was over clocking and had it running stable at 3.4 with 1.6v ? i dont have any other motherboards to try it out on
I'm gonna say your motherboard is having issues but it could be either one. Did you take the motherboard battery out so it will reset the BIOS?
i tried wat was suggested no difference fans flicker on and off still thnx for the help im in the process of an rma hope its my mobo that just went dead
Yep, that aux 4 pin supplies the cpu power and it appears that your motherboard cpu voltage regulator circuit was not up to an overnight OCCT run. You did not mention what heatsink/fan you were running but when you get the new board back I would make sure you have lots of air blowing on the components around the cpu socket.
my cpu is water cooled and what u just said my freind at work suggested was the probelm he told me the transitors for the cpu probally blew :(
