Help please. Mobo for Q6600 / Overclock / Sub $100
Anthroc
I don't need RAID or dual GPUs I just need an affordable board for my new build.
I have a Q6600 and a single 8800GT 512mb that i wish to overclock on air only.
I'm thinking of using 1066 RAM...
What's the best sub $100 or $120 limit solution for my needs?
Check out the Gigabyte P35-DS3L - should fit the bill pretty good. Strange, Newegg isn't even listing the DS3L right now - microcenter has it for $119 though, and NCIX has it for $100. Abit IP35-E is also a good choice at $90.
I recommend this motherboard:
Gigabyte GA-P35-DS3L Intel P35 Motherboard - $86
Also, you do not need DDR2 1066 RAM with the Q6600. C2D systems do not benefit from having faster RAM in non-OC situations or having the FSB and RAM at anything other than a 1:1 ratio. Also remember that the FSB of all Intel CPUs are quad pumped. So if you see a C2D with a FSB of 1066Mhz, the real FSB is actually 266Mhz. Some math for you:
Multiplier x FSB = CPU Speed
2 x FSB = RAM Speed
Q6600:
Multi x FSB, RAM Speed = Clock Speed
9 x 266Mhz, DDR2 533 RAM = 2.4Ghz <== Stock Speeds
9 x 333Mhz, DDR2 667 RAM = 3.0Ghz <== Good OC
9 x 400Mhz, DDR2 800 RAM = 3.6Ghz <== Excellent OC, About the Max
So, as shown above, you do not need DDR2 1066 RAM.
thanks for the help guys. i'll take a closer look at these models.
thanks for the advice about the ram. makes sense. I'll probably get ddr2 800 then
I have the above MB and it easly gets to 3.5ghz with DDR2-800 ram and a good cooler and a slight bump in voltage. (I did put a fan on the NB cause it was a bit hot)
